Ability to set defaults that would hold when starting new scene
I would like the ability to set defaults that would hold when starting new scenes.
Examples
UVW Maps would default to Box and unchecked Real-world map size
Material editor would remember the material map slots
Remember exposure control settings
New materials would default to Standard
light presets
default to standard not Photometric
Omni lights would remember shadow parameters settings
Light lister would remember omni multiplier settings
Render settings
Would remember to use Quicksilver vs Art Renderer
Maintain use Ambient Occlusion
These are just some examples of task I routinely do every time I start a new scene.
If there is a way to preset some or all of these I will not request it. Otherwise I would like to suggest this in the new ideas forum.
Any outer suggestions that need mentioned we could add it to this list.
In AutoCAD you can save as dwt which is a template file and you setup everything once then save the file to the template file which is opened on new drawings
Thank you!
3 Comments
Tupaia
Another good one!
Again, Cinema4D can do this already.
Load the attributes=parameters of any node=object into an Attribute Editor, and in the AE's menu Edit, choose 'Set as Default'.
It shows a waring dialog then, asking if you are sure to overwrite the object's default type.
Works for pretty much everything that has attributes.
In Softimage, it's also possible. In any Property Page, above parameter sets, there's a little RMB context menu with an entry "Edit", that will load the .spdl file with the param defs into a text editor. You can change the defaults there and overwrite the file.
Swordslayer
Sounds to me that what you listed is already (mostly or completely) there:
currentdefaults.ini : UVW Maps would default to Box and unchecked Real-world map size
current defaults / maxstart.max : Material editor would remember the material map slots
maxstart.max : Remember exposure control settings
current defaults : New materials would default to Standard
not sure what you mean here, just don't use photometric? : default lights to standard not Photometric
currentdefaults.ini / 3dsmax.ini : Omni lights would remember shadow parameters settings
not sure once again : Light lister would remember omni multiplier settings
current defaults / maxstart.max : Remember to use Quicksilver vs Art Renderer
maxstart.max : Maintain 'use Ambient Occlusion'
But I really like the approach @Tupaia shows to set a default value for an arbitrary parameter.
electrotoast_old
Status changed to: Archived
Archiving this as there is already a template system that does the majority of this. Check out the AKN for more info. There are some aspects it doesn't maintain like what Tupaia mentioned below, however that is covered under a different idea here. Add your vote on this.
