Editable default values
I do a lot of models and often I have to, for example, weld vertices. Once I've added a value of 100 to it, and now every time I call a window to weld the vertices it always costs 100 and I have to change it to 1 (I need a value of 1, since 100 is too much).
Probably there should be a last value, but for some reason it does not work for me, and there it always costs 100.
And doing it every time is tedious.
Can I somehow set the default value that I want in these windows? For example, how is this done in Cinema 4d and Maya?
A similar technique can be applied to other objects, for example, I as a modeler when I create a plate always do a superfluous operation - I remove the number of segments from 4x4 to 1x1, when I create a cube I remove segments up to 1x1, etc.
1 Comment
electrotoast_old
