Why is my final render frame buffer different?
georaylin
georaylin
Hi all, I'm new to this 3d max section here.
want to find out why the frame buffer is different when I tried to do my final render.
one is without the side settings while I'm doing final rendering
and this was during my interactive render which is the frame I've been trying to use on my final rendering.
Hope someone could give some advice on this issue.
Thanks!
RobH2
It would help if you could give more information.
What are you doing and what are your settings? What have you tried to fix it, read documentation, etc.
It looks like your are rendering a really small final image. It's 694x411. Render something around HD or 1920 and see if it looks better.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
CAMedeck
I'm a little confused at your screen shots.  What you labeled as your Final render is the Max Frame Buffer.  The Interactive render is showing the V-Ray Frame Buffer.
Are both being rendered with V-Ray?
Chris Medeck
