3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Water material
15 REPLIES 15
Message 1 of 16
855 Views, 15 Replies
Water material
When ever I try to render with the Ground Water material it says lakerem.jpg external file is missing. Any idea what I might be doing wrong,
15 REPLIES 15
Message 2 of 16
Steve_Curley
Which version of Max?
If it's a full install (from CD/DVD) then that map can be found (several times) in the Samples directory on the distribution media - often on the 2nd disc depending on the version.
The map is being used in the Reflection Map slot of the Ground Water material (and several others). Substitute <installdir>\Maps\Backgrounds\lakedusk.jpg if you have it - it's the same image.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 3 of 16
where did you find this "ground water" material? which shader? is it a template?
Message 4 of 16
Steve_Curley
It's in the default Material Library (3dsMax.mat).
Max 2016 (SP1/EXT1)
Message 5 of 16
that would explain why I didn't know of these materials.. I don't have any material librairies installed... (yet I did chose the "material librairy" option in "custom" installation when installing max... if I remember correcly
Message 6 of 16
Steve_Curley
Are you sure they aren't installed? Check in your <installdir>\materiallibraries folder. If they are there - use the "open" option in the Material Browser to get at them.
Max 2016 (SP1/EXT1)
Message 7 of 16
srry for stealing the thread like this...
Message 8 of 16
Steve_Curley
Perhaps a "custom install" wasn't a good idea?
Max 2016 (SP1/EXT1)
Message 9 of 16
Any idea on how to fix this?
Message 10 of 16
Steve_Curley
Did you not read my 1st reply?
If it’s a full install (from CD/DVD) then that map can be found (several times) in the Samples directory on the distribution media - often on the 2nd disc depending on the version.
The map is being used in the Reflection Map slot of the Ground Water material (and several others). Substitute <installdir>\Maps\Backgrounds\lakedusk.jpg if you have it - it’s the same image.
If you don't have either of theoe files then substitute any outdoor scene that you have - the results won't, of course, be identical but it will remove that annoying warning.
Max 2016 (SP1/EXT1)
Message 11 of 16
Sorry about that I am working on 3DS Max 2008. Thanks for your interest.
Message 12 of 16
Steve_Curley
Then go look on the 2nd DVD in the Samples directory - that's where it is. If you don't have DVDs then you have the trial and that map IIRC was indeed missing. Substitute another image as I suggested.
Max 2016 (SP1/EXT1)
Message 13 of 16
I'm sure that you've found the files by now. I just installed 2008. For some reason it opens a Materialslibrary file under My Docs, but doesn't put anything in it. All the files were installed under Program Files\Autodesk\3dsMax2008\materials and materialslibrary. Crazy!
Message 14 of 16
Steve_Curley
Annoying, but true. Look up "Project Path" in the help - that's the culprit.
Max 2016 (SP1/EXT1)
Message 15 of 16
Nick,
Here is the file you are after, extract it to the appropriate folder.
Hope this helps.
ivan
8449_H6QQoCtwabxYj75qxzJI.zip
Message 16 of 16
Thanks guys for your help worked, Thank God for The Area
