3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
walls dont snap
8 REPLIES 8
Message 1 of 9
3854 Views, 8 Replies
walls dont snap
snap to end works but not with walls? Anyone have this problem?
8 REPLIES 8
Message 2 of 9
leeminardi
Adding a wall using Vertex of Edge/Segment to snap to an existing wall works for me in 2014.  To add a window to a wall I use snap set to Face.
~Lee
lee.minardi
Message 3 of 9
in reply to: leeminardi
im trying to snap to a plan or rectangle or shape. snap to endpoint or vertex does not work with wall in 2016
thanks
Message 4 of 9
kgokhangurbuz
Hi, if your object to snap has a different value then "0" in Z axis, snaps for AEC Extended > Wall does not work.
Please;
-Move your object to "0" position on Z Axis
-Or go to AEC Extended > Wall > Keyboard Entry Rollout > Click on Pick Spline, then Click on the object you want a wall to be created on.
Best regards;
Message 5 of 9
leeminardi
I drew a rectangle in Max 2016 then set snaps toggle to vertex. The wall snapped to the corners of the rectangle.
This seems pretty straightforward so there must be something else that you are assuming that is not clear to me.
~Lee
lee.minardi
Message 6 of 9
kgokhangurbuz
Hi;
Easiest way to explain what i am saying is;
If you move that rectangle in Z axis (either "-" or "+"), your snaps will not be working.
I think that might be the case in your very first post.
Message 7 of 9
in reply to: kgokhangurbuz
THANK YOU!
That was the issue!
Message 8 of 9
thank so much , it works with me too
Message 9 of 9
2020 year, still helpful, I did it and works now. Thanks
