vray's ambient occlusion
Did they remove ambient occlusion when they went for 3.0 to 3.4?
cant find it here but in a tutorial (second image) its there.
https://gyazo.com/40faf35a93cf7b2afeb92f566ebe44d6
https://gyazo.com/5e7862a14c1951ee66c46df143fdc91e
rendermaster
Under Global Illumination, press the button with word DEFAULT until it change to ADVANCED / EXPERT and you will see Amb. Occlusion parameters
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
This kind of annoying check this out. I was excited to click on the default and today there is nothing.
https://gyazo.com/33b4c3f9d84e66aa1931a544cc950015
I think i am still have some licence issues. Guess i need to talk to Chaosgroup
rendermaster
you just need some refresh it think, restart 3ds max, create new scene and check
Alfred.DeFlaminis
That is strange, usually if the license isn't found it stays not found.  I haven't seen it get dropped before... Chaosgroup should be able to help there.
I went ahead and marked @rendermaster's solution since it is technically correct.  Another method to make some AO (less realistic but renders faster) is:
1) Make a VrayLightMtl
2) Put a VrayDirt in the color
3) Check "Adjust to camera exposure" (or whatever that's called)
4) Set the AO distance in your Vray Dirt
5) Put this VrayLightMtl in your override material slot.  (F10-> Vray->Global Switches-> Check Override MTL.)
Then render this separately, and composite together in post using the AO on top set to Multiply with an opacity of 35-50%.
However, @rendermaster's is the true AO and it's better because it'll be affected by lights in the scene so you don't have AO running right next to a lamp or something.  Sometimes though time doesn't permit and some masking in photoshop with this method can help.
Best Regards,
Alfred.DeFlaminis
