I'm beginner and I'm not getting a proper displacement using VRay displacement mod.
the left side of mesh is not displaced as right side.
It's kind of impossible to see exactly what you are describing. Can you upload a file or a few more images?
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------Hi @prajwalrior ,
Is this based off a baked-out height map, or does Vray generate it on the fly? I do see that the left side isn't as detailed as the top, here is a suggestion.
If you are able to bake out the map, take the 4k (or whatever res) map into an image editor like Photoshop, you can do a sharpen modifier on that section, it might get you the result on that. You can also duplicate the layer and do a "high-pass" filter (under filters > other). Basically anything to sharpen it up.
Also i would advise using a png or other lossless image format like tiff, png or Targa, not jpg.
Best of luck!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
