3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
VRay displacement is not applied across the mesh.
2 REPLIES 2
prajwalrior
433 Views, 2 Replies
I'm beginner and I'm not getting a proper displacement using VRay displacement mod.
the left side of mesh is not displaced as right side.
2 REPLIES 2
RobH2
in reply to: prajwalrior
It's kind of impossible to see exactly what you are describing. Can you upload a file or a few more images?
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
hagen.deloss
Hi @prajwalrior ,
Is this based off a baked-out height map, or does Vray generate it on the fly? I do see that the left side isn't as detailed as the top, here is a suggestion.
If you are able to bake out the map, take the 4k (or whatever res) map into an image editor like Photoshop, you can do a sharpen modifier on that section, it might get you the result on that. You can also duplicate the layer and do a "high-pass" filter (under filters > other). Basically anything to sharpen it up.
Also i would advise using a png or other lossless image format like tiff, png or Targa, not jpg.
Best of luck!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
