- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
i wanted to know the use of this radio button of vertex color in volume select modifier, any help is highly appreciated.
Vertex color (channel) is mapping channel much like other map channels
and other map channels are vertex color channels much like... you know...
You can paint vertices by changing mapping coordinators and vice versa...
But most likely you would use that with Vertex Color Map (map channel 0) as selection source.
2. Temporary overriding sub-object selection...
Dont see any use of that, never use it... So will not explain in more details.
