Transparent reflective floor
vvachula
Observer Observer
vvachula
Observer
Observer
I used Max years ago as an exhibit designer. Back then, I was able to make a transparent material with nothing but raytrace reflections to achieve a floating reflection on the "floor" where my design would sit. My plane was completely invisible and only the reflections of my exhibit would render. (I am attaching a jpg for clarity on what I'm describing.) Now, with materials being real world based, I can't seem to achieve this same look. The floor wants to reflect the lights and the background, and I can't make it invisible while still having the reflections render. Is there a way I can do this in 2024? I am using the Arnold render engine. Thank youExhibit_Blank.jpg
MartinBeh
The Ray Switch Shader in Arnold allows you use different shaders depending on whether it is the first raytrace hit, the second etc. Also take a look at the Trace Set shader, which lets you define sets of objects that can "see" each other or not.
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
MartinBeh
Or you add an Arnold modifier to those objects that should not reflect and turn of specular reflections:
