Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Transfering Objects between files?
For example, lets say that I have 5 objects in a scene and each one contains modifiers, how can I transfer the 5 objects (hopefully with their modifiers) to a different 3ds max file / scene?
I know I could just export every single object as an .OBJ, but that would be really slow if I wanted to transfer more than 5 objects, plus they wouldn't have the modifiers anymore.
So its there a way to do this or not? 😄
Steve_Curley
AppMenu > Import > Merge (or File > Merge for old releases).
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Thanks!
CAMedeck
I once came across a script that said it would allow you to copy and paste models between open scenes.  On ScriptSpot.com if I recall correctly.  I didn't try it, but thought it was intriguing.  Might be worth a shot as well.
Chris Medeck
Just to add to the conversation, you can also xref objects between scenes. 🙂
