3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
there is no disk in the drive. Pleas insert a disk into drive\Device/Harddisk1/DR1
19 REPLIES 19
Message 1 of 20
1804 Views, 19 Replies
What would cause this message with starting 3ds max.
thanks
19 REPLIES 19
Message 2 of 20
irishman_team_kilber
is this a physical of 3ds max or a digital download? and what version do you have?
just uninstall 3ds max and reinstall it see it that makes a difference
Message 3 of 20
in reply to: irishman_team_kilber
Both 2020 and 2021 do it. They are both digital downloads. Thanks
##- Please type your reply above this line
Sent from my Verizon 4G LTE Droid
Message 4 of 20
do you have access to a USB Copy the entire installer folder from the installation USB drive to your desktop. Once the folder is copied to your desktop, open it and run the file Setup.exe (the F/X CAD installer file). see if this works  this comes from the autodesk autocad help room they say it's a bug.
https://www.landfx.com/kb/installation-help/fxcad/item/3189-insert.html
i cannot verifiy if this will work with max
Message 5 of 20
I don't have a usb copy only the download. I uninstalled and reinstalled and it did not solve the problem
Message 6 of 20
mark you don't need to have a copy on USB all you have to do is copy the installionation files across to the USB as it says in the link i gave you
Message 7 of 20
All due respect @irishman_team_kilber it says ?Copy the entire installer folder from the installation USB drive to your desktop?
You saying do the reverse of this?
Message 8 of 20
yes copy your 3ds max installation from your hard drive to your USB if this doesn't work then i am not sure what you can do
you can possible do Perform a clean uninstall
Message 9 of 20
I did a search on my hard drive for any directory containing Landfx* (just trying to find the directory containing the f/x installer file ) or F/X* and found nothing. Also in your reference link it references autocad 2016 not 3ds max. are we talking the same issue?
Thanks for getting back with me on a Sunday
Also i did a uninstall and reinstall
Message 10 of 20
there is no Landfx i said open 3ds max installation menu and then copy them over to your USB.
I give up i cannot help you anymore i will let someone else take over
maybe @10DSpace or  @leeminardi can help you out
Message 11 of 20
As I said just trying to find the directory that contains the file FX Setup.exe. Landfx, just happens to be in that directory you refereed me to and i thought i was unique enough to do a search to find the fx exe file on your second post refers me too. Thanks for tying. have a wonderful day!
Message 12 of 20
So I believe what your saying is this. I copped the following on my usb drive. I will do an uninstall and run setup form the usb drive. Ignoring any FX Setup.exe file as your first reference suggested.
Message 13 of 20
Your right Ill bet my old buddy Lee will be able to help 😀  have not talked to him in a while
Message 14 of 20
leeminardi
@Anonymous Thanks fro the vote of confidence but I cannot help you with this. I think this is something to ask Autodesk support for help.  I assume 1000's of users are installing Max without a problem so it may be something with your download or computer configuration.
Good luck.
lee.minardi
Message 15 of 20
in reply to: leeminardi
Thanks Lee
Message 16 of 20
jon.bell
@Anonymous ,
This may be caused by Max having asset paths set to a drive that's no longer connected (external HD, scratch disk, etc.)
This is an old thread, but the suggestions/solutions offered here may help. Please let us know!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
Message 17 of 20
in reply to: jon.bell
Thanks @jon.bell for you input. I checked and verified that the autoback is saving to my hard drive. Is there another area i should check?
Message 18 of 20
But then you said asset path. Could this be a material? Im wondering how i can have any path issues if i did a reinstall.
Message 19 of 20
jon.bell
@Anonymous ,
A 3ds Max reinstall doesn't clear out your customized user preferences; you have to do that manually.
You can do that by following these instructions to reset your preferences.
Please let me know if this helps, and I hope to hear from you soon!
Jon A. Bell
Message 20 of 20
Thanks @jon.bell
I renamed the enu file and that did nothing. I guess I am going to just live with it. The program seems to function fine when i just select continue. hopefully it will not bit me later. Hopefully there will be a patch for it later
