Start 3dsmax with WORLD in the Reference Coordinate System
yCekyLL
yCekyLL
Hello everyone!
I would like some help with a script that I have already tried to get here and we have not been able to find an answer...
____________________
Whenever 3dsmax starts, it sets the "Reference Coordinate System" to "View". - and does this for the 4 manipulation tools:
- Select Object = View
- Select and Move = View
- Select and Rotate = View
- Select and Scale = View
What I would like is a script that runs automatically at startup and changes all 4 tools to "World".
_____________________
I know that doing this manually is not difficult for experienced users, but when I am introducing these tools to new students, it becomes much more complicated if we start with the reference in "View" because it is different in each type of viewport.
Thanks for the help!
MartinBeh
To start with you could change the preferences for all four tools to share the same Reference Coordinate System. So if you change it for one, you change it for all of them.
Then you could take what you got in https://forums.autodesk.com/t5/3ds-max-forum/world-local-toggle-by-script/td-p/13403369 and simple place this into a setcoordsysworld.ms file:
toolMode.coordsys #world
and then place that file into one of the startup folders, e.g. C:\Program Files\Autodesk\3ds Max 2024\scripts\Startup
Then restart 3ds Max to verify.
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
yCekyLL
Hello Martin.
Thank you for your attention, but I think I didn't understand what you said or your solution doesn't work... let me confirm what you said:
"...preferences for all four tools to share the same Reference Coordinate System"
I have no idea where this is in the preferences window. In my entire life, each tool has and "remembers" its last setting independently of the other tools.
__________________________________________
About using "toolMode.coordsys #world" it even works as a single command, but it is applied to the current tool.
What I really needed, as I explained initially, is a script that would change the system for the 4 tools.
I also didn't understand how to use the script from my other post that you linked... I really don't know much about scripts, I wouldn't know how to combine both and I can't imagine how to ask the script to do it automatically for the 4 tools!
But I appreciate the attempt! And I always like and accept the solutions!!
MartinBeh
With regards to always use the same coordinate system, please see this post:
https://forums.autodesk.com/t5/3ds-max-forum/reference-coordinate-system-script-to-make-world-defaul...
In a nutshell:
Main menu > Customize > Preferences > General > Ref. Coord. System > Constant = on
Here is also a link to the online help explaining this
https://help.autodesk.com/view/3DSMAX/2022/ENU/?guid=GUID-7FAE565D-05D2-4E34-98D0-490B6BBC3D0C
Once this is set, 3ds Max will remember it. Now all that is left to do is to create a simple text file, place the line
in it and then save it with the .ms extension in a startup folder, e.g. under C:\Program Files\Autodesk\3ds Max 2024\scripts\Startup or C:\Users\<yourUserName>\AppData\Local\Autodesk\3dsMax\2025 - 64bit\ENU\scripts
yCekyLL
Hello Martin.
Thank you very much for the information.
I hadn't really noticed that option in Preferences, I thought it was related to the "Snap \ Translation \ Enable Axis Constraints" option.
I created the script in the Start folder and everything worked out fine.
I'm going to put it here as solved because it works very well for working with beginner students.
But in professional work, there are situations where you need to work with different reference systems for each manipulation tool. For example, moving a car on a ramp while adjusting the rotation of the wheels - that would be one case.
So, the original idea of ??setting all 4 tools to world in startup, maintaining their independence without having to go to the preferences menu, would be more than perfect!
Who knows, maybe one day!
Thank you again for your help!
MartinBeh
This little script should do that for you:
	desiredMode = #world      -- can be: #view #screen #world #parent #gimbal #local #grid #working_pivot
	old = toolmode.commandmode
	for m in #(#SELECT,#MOVE,#ROTATE,#NUSCALE,#USCALE,#SQUASH) do (
		toolmode.commandmode = m
		toolMode.coordsys desiredMode
	toolmode.commandmode= old
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
