[Reference Coordinate System] Script to make 'World' default?
skyd7
skyd7
Hi, I rarely (if ever) use "View". It really bugs me having to change it every time I select an object. I did used to have a script years ago, but have since lost it. Is there a way to change the default now, and/or a script?
Many thanks.
MartinBeh
Make sure all tools use the same coord sys:
Customize > Preferences > General > Ref. Coord. System > Constant = on
Then run this line of code to change to world coord:
toolMode.coordsys #world
That line could be placed in a startup script, e.g. by placing it in a file called startup.ms which is stored in ""C:\Users\<yourUserName>\AppData\Local\Autodesk\3dsMax\2025 - 64bit\ENU\scripts", for example.
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
skyd7
Super- thank you!
