Hello Folks, Can anyone tell me what these squares are. All my modelling is done in Mcad software [ Brep ] and taken into Max as an stp file. I can delete the squares without it affecting anything I do, i'm just curious as to what they are.
Solved by leeminardi. Go to Solution.
It looks like they could be dummy objects. Click on File, Summary Info..., to see if the file contains dummies.
@leeminardi , Many thanks, what exactly are dummy objects ? and do they actually come from the cad model? They certainly have no effect on anything I need to do. Maybe they are for animations, I just don't know.
Dummy objects are typically used when rigging a model for animation. They can provide a reference point for other objects. You can probably ignore them and perhaps delete them if you do not have objects moving with respect to each other.
@leeminardi , Thanks for your help with this, they are indeed dummies [ see attached screenshot ] I delete them as a matter of course as I don't do animations. [ just wish they were not created in the first place ] still it does not effect my work.
many thanks 👍
