3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Slow UI
5 REPLIES 5
coilbookmedia
659 Views, 5 Replies
Slow UI
coilbookmedia
Max got worse with slower and slower UI. More you use it slower it gets to get into modified object options even native stuff like Sub objects options for edit poly etc.
Watch this video made by Itoo even they have problems  https://youtu.be/2fTWWd5N6qU?t=15
please fix it.
Slow UI
please fix it.
5 REPLIES 5
brentscannell
Hi @coilbookmedia
What version of 3ds Max are you using? I'll be the first to admit that there were problems with the UI speed, especially when switching between subobject modes in editable poly, but we've done 3 iterations on that code since to make it more performant. The attached video shows me switching SO modes in 3ds Max 2018.4 on the left, and an early build of 3ds Max 2021 on the right. 3ds Max 2021 went live today.
Hi @coilbookmedia
coilbookmedia
Thank you.  We still use 2020 due to a lot of plugins not supporting 2021.  Can you release 2020 patch fix it?
brentscannell
These fixes are included in 3ds Max 2020, just make sure you've grabbed the latest update as they were pushed in 2020.1. The latest is 2020.3
And most, if not all plugins should work with 3ds Max 2021 as well. We did not break plugin compatibility with this release, but you may need to force install them into the 2021 folders if the plugin vendors haven't updated their installers yet.
coilbookmedia
Thank you!
Thank you!
coilbookmedia
It seems that max even 2020.3 version gets slower and slower overtime and usually PC or max must be restarted. I attached the video how slow is Forest Pack to open after selecting it.  Thanks
