Sketchup to 3ds workflow issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a problem importing a model made in Sketchup to 3ds 2017.
The model has metal balustrade elements made by more than 18.000 objects in the same layer.
Once I import in 3ds every single metal bar (which become meshes in 3ds) from the balustrade is a separate object slowing down a lot the handling speed of the max file (the max file takes 20 mins to just open). Everything is fine if I merge all the bars in one geometry but this process takes ages.
Is there any way I can import all the elements in the same layer in just one object???????
You can find here a screenshot to show how the metal bars have different wire colors because they are independent objects to each other, also you can find a screenshot with import settings.
Many thanks!
