share view missing from menu
bertv
Message 1 of 11
bertv
3D studio max had a "share view" option for some time. This feature disappeared recently on all our 3D studio max
2020 and 2021 installations. Probably with an update install.
It should be located under file/share view
I tried adding the feature back by adding it to the UI from the toolbar menu. But refuses to work.
Any ideas?
Replies (10)
Message 2 of 11
DarrenP
what version of 2021 you are on?
the latest version is 2021.3.2
this menu shows up for me
DarrenP
Message 3 of 11
bertv
I'm in
2021.3.2 Security Fix
23.0 - 23.3.2.3508
Message 4 of 11
bertv
Could this be renamed or relocated in 3D studio max?
As it seems, the Autocad share view version is still working.
The only work around I found is making an archive for the data and manually uploading it to the share view main page on the Autodesk site. It's a lot more work, but does the job for now, until a solution is found.
Message 5 of 11
DanielCantin
Hi @bertv
Have yo tried to reset the 3ds Max preferences to defaults as mentioned in this support article:
Share View option is missing from File menu in 3ds Max?
Daniel Cantin
QA Manager, 3ds Max, Maya
Entertainment Creation Products, ECP
Message 6 of 11
bertv
@DanielCantin
Yes, I did the reset.
Without result 😞
Bertv
Message 7 of 11
bertv
We just find out there was a problem with some of our licenses. So hopefully fixing this will fix the shared view problem!
Message 8 of 11
bertv
Nope, still missing in our max versions.
Message 9 of 11
bertv
Hey,
I found out the issue could be caused by a custom render engine.
I started a post on their forum:
https://forum.corona-renderer.com/index.php?topic=34735.0
Message 10 of 11
tshaw
I can agree that installing Corona somehow deletes it from the menu drop down. To add it back in I go to "customize User Interface" and create a new toolbar with the "Share View" function, then hit "Save". After restarting the application the toolbar still exists and the feature shows up n the "File" menu like it's supposed to.
Message 11 of 11
bertv
Hi tshaw,
Thanks for this solution. It finally works again 😁
