Hello, community!
I know this subject was posted before here, but my situation is slightly different. I've already tried what others suggested as possible solutions. None worked.
Here's the effect:
Picture (1):
Renderer: Mental Ray
Details: Shadows appear in good quality when in Perspective Viewport. When rendering, shadows do not show. Objects show expected world reflection (complex object is 'metal'. Sphere is 'chrome').
Picture (2):
Renderer: Scanline
Details: Shadows appear in good quality when in Perspective Viewport. When rendering, shadows appear incomplete. Objects have opaque polygons (no world reflextions).
My scene has a big dome-like sphere with a 'sky and clouds' bitmap, a plane with the wooden texture, a spotlight with a big falloff and small hotspot, and these two objects. Even though (2) shows the objects floating, they are both "resting" on the wooden floor. I'm working inside the dome.
I've already checked all possible parameters for the shadows in the spotlight, in the render setup, as well as the shadow casting in the objects parameters.
Any help will be greatly appreciated!
it would be better if you can share the file/s in here.
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Hello @Anonymous and welcome to the community,
My first instinct tells me the objects are not touching the floor, the shadow bias parameter is overly high, or the XForms need to be reset on those objects. Would you mind posting a sample file, please?
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Hello @Anonymous,
I just wanted to follow up here, any thoughts on my previous post? Thanks for the update!
Best Regards,
