Shaded objects turning invisible
raghavtyagi444
Observer
Observer
raghavtyagi444
Observer
Observer
Hi, I work on 3ds max 2023 and I recently bought a new PC in which my shaded objects are turning invisible(not hide) on their own, I wasn’t having this problem in my previous PC anyway I tried changing my display drivers which kind of fixed the problem but It’s laggy as hell so I was wondering if there was any other way to fix without getting lag?
Thank you
Diffus3d
I think the problem might be inverted normals on the base of the bed. Also looks like the nightstand is set to x-ray or transparency mode, try selecting the end table and pressing alt-x.
If not, you can try different display drivers to see if your performance improves.   Lastly, you can try reducing the viewport display settings in the upper left corner of each viewport.
Best Regards,
Alfred (AJ) DeFlaminis
View Max Tips/Tricks Megathread
raghavtyagi444
Observer
Observer
Tried different Display drivers and restarted the whole PC with restored factory settings it worked, thanks
