Select, Place and link in Max Interactive
adjust1965
Message 1 of 16
adjust1965
I want to grab an object and put it on a rotating disc. The object should then rotate with the disc. How can I link the item to the disc when I drop it? What settings do I need to enter in unit flow?
Thanks for the help
Werner
Your post subject line has been edited by @hagen.deloss: Selekt, Place and link
Replies (15)
Message 2 of 16
miledrizk
1- choose the Select and Link too
link.PNGl
2- Now click on the object you want to link, don't release the mouse button,
    Drag until you're on the disk and release. Now when you move, rotate or scale
    The disk the object will follow.
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
Message 3 of 16
adjust1965
Hello … thanks for the answer. I am in the Autodesk Interactive, not im Max …
Sorry, i forgot to say ...
Werner
Message 4 of 16
hagen.deloss
Hi @adjust1965
Thanks for bringing your question to the forums, it looks like you are visiting as a new member to the 3DS Max forum. I want to extend a warm welcome to the Autodesk Community!
I haven't gotten a chance to learn much about 3DS Max interactive, you may have better luck posting in the Max Interactive forums here. I'm also wondering if @gustavo_bergoya1 or @__ben__ have any suggestions!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 5 of 16
hagen.deloss
Hi @adjust1965
I wanted to mention, if you are unable to find a solution within Max interactive, you can try baking out the animations inside 3DS Max and importing the two objects into the engine.
Baking animations:
  • Select the object
  • n Command Panel Motion > Trajectories
Sample range
  • Start frame
  • End frame
  • Samples (This is the 'tricky' one, Sample is amount of keys for time start to time end) For 1 key per frame, set sample to the frame count)
  • for instance, 0 to 100, sample should be 101 (including frame 0)
Choose the Transforms you want to bake (Position, Rotation, Scale) default is Position and Rotation, then click 'Collapse' button. This was paraphrased from a forum post here.
I hope this helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Message 6 of 16
gustavo_bergoya1
Hi group
Use this parameter:
Attached i send you The physic materials file setting
Regards
Message 7 of 16
gustavo_bergoya1
global.physics_properties
Message 8 of 16
hagen.deloss
@gustavo_bergoya1
You are awesome! Thanks so much for the helpful posts 😄
@adjust1965 It would be super helpful if you could add a post with how you decide to proceed, and your results. That way other Community members can benefit from your process 😄
Hagen Deloss
Message 9 of 16
gustavo_bergoya1
Message 10 of 16
adjust1965
Hello everybody,
I think it's great how I'm helped here! Leather does not work for me. Is probably synonymous because I have only been working with Interactiv for 2 weeks ...
Can you tell me which settings I have to make in the Unit Editor / Flow Editor and in the properties for the turntable and for the cube? The dice should also be placed on the turntable by pick and place. Sorry for my bad English.
Thank you very much in advance.
greetings from Germany
Werner
Message 11 of 16
gustavo_bergoya1
I'm going to prepare a video.
Message 12 of 16
adjust1965
You are the best!
Message 13 of 16
gustavo_bergoya1
Previously I had not done something like this exercise. I hope it will be helpful to start with this topic.
Adjust, I think if you are starting in 3ds Max Interactive, you should start with more basic exercises.
Video:
https://autode.sk/2PVz7fP
Regards
Message 14 of 16
adjust1965
Hello Gustavo,
it works!!! Verry heppy!
it's very easy to have such a good workshop as you created it. Thank you for that, is really great.  The only problem is that I work with VR glasses. The BASIK Template does not work with it. I Need the Desktop VR Template.  This is not working whis yours global.physics_properties. And now?
Regards
Werner
Message 15 of 16
gustavo_bergoya1
Look this tutorial video of youtube, attached of this you can find the Flow
https://youtu.be/BWEazyueW2s
I do not have VR glasses for now, soon when I have them and learn how we share information
Use this online template that shows how to do it:
VR Museum
look what can be done
https://youtu.be/OwWoWU3flIs
Regards
Message 16 of 16
adjust1965
Hello Gustavo,
did you get my private mail?
Greetings
Werner
