i have create a standard beach scene.
i have create a box with spline line and then used constraints path to animate the box moving down the line to the sea water. i am wondering the best way to make it box hit the water with a splash. i have seen a couple of half tutorials on youtube tell me you have to use the particle view. but due to the tutorial it's only half complete.
I put this in the animation but no one answering in there
please help
Thanks Anthony
Solved by 10DSpace. Go to Solution.
You didn't say what half tutorials you watched, but check out this one using Max fluids (using no external plug-ins) which seems to be similar to what you are trying to do:
https://www.youtube.com/watch?v=76hHFst4APw
Some other tutorials of interest are here:
Hope it helps.
I don't have fluids because i have a older version of 3ds max and cannot afford to update my 3ds max
