scene zoom pan acting strange
I'm not sure if this is a bug or just some setting I am not aware of. Notice my xyz at the bottom of the scene. I select in space to as i often do to get out of the command and it shoots me in outer space.
https://gyazo.com/bcf7a65cc852a6325a076618a87aa105
Some times its fine and other times is terrible.
Alfred.DeFlaminis
Hello @Anonymous,
There are two things that have an effect over this.  The first is the type of orbit mode you are currently using in combination with where you clicked to rotate the world.  If you want to orbit around the object, keep it selected.  You may also find that a different orbit mode is better for you.  You can adjust them in the bottom right of your interface as shown below.  Hold down a click to expand the menu and see more options.
The other thing that can cause this is if 3ds Max is being run on a 2nd or 3rd monitor instead of the primary one.  The easy fix is to make the monitor it is on the primary monitor, or move it to the primary monitor.  It will work in 2nd or 3rd monitors as long as they are the monitors with the most DPI, otherwise things like this can happen.
Please hit the "Accept as Solution" button if my post fully solves your issue or answers your question. This lets me know that I was effective in helping you, and thank you for doing so.
Best Regards,
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on your issue?
Best Regards,
I am running 3 monitors I will log and keep your suggestions in mind the next time i run into this.
thanks for all of your help Alfred!
Alfred.DeFlaminis
Hello @Anonymous,
Anytime Markr, anytime!  I'm working on a video for your other post now, will upload after lunch.  Have a great day!
Best Regards,
awesome! thanks
