3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Scene Thumbnail 3DS Max 2016
29 REPLIES 29
Message 1 of 30
11027 Views, 29 Replies
I've read previous posts from a few years ago, but haven't seen anything recent. Is there a way to see thumbnails of Scene files in Windows Explorer?
29 REPLIES 29
Message 21 of 30
reallukx
After doing MaxThumbnailShellExt.dll run latest 3dsmax 2018 sp3 and check
repair
http://lukx.com
Message 22 of 30
in reply to: reallukx
Hi Kudos,
Thanks for your help, but I can't seem to find a Service pack for 2018 other
than
tent/3ds-max-2018-populate-high-resolution-data.html> 3ds Max 2018 Populate
High Resolution Data
Thanks in advance.
Theo
Message 23 of 30
Thanks for your help, but I can’t seem to find a Service pack for 2018 other than 3ds Max 2018 Populate High Resolution Data
Thanks in advance.
Theo
Message 24 of 30
Sorry, found it. Thanks
Message 25 of 30
I did run sp3 2018, but no luck unfortunately, any more suggestions?
Nice work at your site btw
Message 26 of 30
Orangetheripper
in reply to: artgrail
@artgrailwrote:
A small addition, how to change the overlay max icons in thumbnail view:
There’s a branch in the registry, here:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\SystemFileAssociations\
So if you add .max extension to it, then add String Value “TypeOverlay” and add a path to 3ds max icon
(for 2017 it’s here: C:\Program Files\Autodesk\3ds Max 2017\Icons\icon_main.ico),
the overlay icons for max files will be changed.
Maybe you need to rebuild the icon cache for this patch to work.
Well I'll be... this actually worked, thank you so much! I tried literally everything else possible and thought I was just going to have to live with those annoying blank icons...
2 notes: I had to get the icon path from a shortcut (drag out the 3ds max icon from the start menu to the desktop, right click, properties, "change icon" and you can copy/paste the icon path to the TypeOverlay string from there).
Also, in order to get the icons to quickly and easily update after you input the reg string, just right click a max file, properties, change "open with" program, and just re-select 3ds max, and it'll instantly update... no need to rebuild cache or even restart.
Thanks again!
Message 27 of 30
in reply to: spacefrog_
Hello...
I am in my 60's and I am having a hard time seeing the models in my Thumbnail viewer ...Question ..Is there away to enlarge the Thumbnail viewer
Message 28 of 30
istan
I am using Total Commander and the 3dsmax preview plugin, which shows the preview image in the resolution in which it was stored..
Message 29 of 30
in reply to: istan
How much is the Plugin ?
Message 30 of 30
istan
the plugin is for free..
