Scene is not visible while rendering
Hello
Whenever i place camera in my view, at the time of render, render screen showing black. I place vray light and render setting too but still the view is black at the time of render.
miledrizk
try to check few thing:
1- camera location, maybe it's inside a wall
2- if it's a Vray plane light, check the orientation of the arrow, since it's in that direction
the light will be emitted
3- Check the visibility of the light from the Options rollout,
If light is visible and it's in front of the camera then you'll see black, in this case
Checking the option Invisible will solve the problem
4- Also you have the location of the light itself, like the camera, check to see if it's not
hidden inside a wall.
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
I add a daylight system where i set it on vray sun and i am rendering exterior view. So i am sure its not in the wall.
miledrizk
If you press 8 on the keyboard is it possible that
in the Exposure Control rollout you have an exposure control method applied?
If that's the case, from the drop down list choose <No Exposure Control>
Also as an extra check, maybe, by accident you unchecked the Enabled Option of Vray Sun
miledrizk@gmail.com
Ok. Thanks ^^
Sarmadrabile
Community Visitor
Community Visitor
photo_2022-07-20_11-49-48.jpgwhen i press render it shows this material ball or it shows black screen what's the problem ??
CiroCardoso3v
That to me looks like an issue with a) normal map has the wrong gamma, b) normal map or bump map is too strong or c) displacement is too strong. Can you show us the material?
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
