Saved image from Corona VFB looks overexposed when ACES OT is reduced (e.g. 0.2)
olesyabobrus
olesyabobrus
Community Visitor
Community Visitor
Hi everyone,
I’ve noticed an issue with saving renders from Corona VFB when using a custom ACES OT value.
In Corona VFB, if I set ACES OT = 0.2, the image looks perfect — highlights are nicely compressed, no overexposure.
But when I save the image (PNG/JPG) directly from the VFB, the saved file looks overexposed, as if ACES OT was not applied at all.
When ACES OT = 1.0, the saved image matches the VFB perfectly.
When ACES OT = 0.2, the saved image no longer matches — it looks blown out, not like in the VFB.
Question:
👉Is this expected behavior?
👉Is there a workaround to make the saved image match the VFB when using a custom ACES OT value?
👉Should I use Corona Image Editor or another workflow?
Thanks in advance for any help or clarification!
haifeng_yuSEVKN
hello @olesyabobrus, thanks very much for sharing the information.
Please note that Conora renderer is a third party plug-in that is not developed by Autodesk, it would be beneficial to contact Chaos Group for more consultations. They will have a deeper understanding of Corona renderer, as they are the developers behind the tool, making them the most knowledgeable source for insights and technical support. Please allow me to attach the contact information below if you need:
Thank you!
Haifeng Yu
Technical Support Specialist
joaquim.moral
Thanks for your support @haifeng_yuSEVKN here!
Your question got successfully answered? Then just click on the 'Mark as solution'
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Joaquim Moral
Senior Community Manager - EMEA / LATAM and Media & Entertainment lead
