3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
SAT file import as 3D SOLID but export as surface
1 REPLY 1
xxpochita123
123 Views, 1 Reply
So I imported a 3D Solid to 3DS Max but everytime I export it as SAT file, the object changes to surface.
This is the original file from AutoCAD.
I imported the file from AutoCAD as SAT in 3DS Max
This is the exported file (as SAT again) from 3DS Max. I opened it using AutoCAD.
1 REPLY 1
Diffus3d
in reply to: xxpochita123
Hello @xxpochita123 ,
Body objects are technically B-splines from what I understand.   Since you don't have any conversion modifiers on the top of the stack there, the object is still just a body object with a bend on it.  If you put an Edit Poly on top and then re-export, or convert the mesh to edit poly then export, does it solve the issue?   I am not familiar with .sat files but is it a NURBS format?
Best Regards,
Alfred (AJ) DeFlaminis
View Max Tips/Tricks Megathread
