Arnold Voiume Animation effect Error
wonilmax
wonilmax
  I implemented a flame effect with Vdb in FumeFx and used arnold volume. I tried contacting FumeFX, but they said there was no problem with their program.
In CPU render everything works fine in arnold volume. However, an error occurs in the GPU rendering result with between only Single and Range in the same Frame. The single test was normal, but the Range was abnormal. This happened when used on animated moving objects.
Replies (0)
