3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Rotate scale and move symbols - 3ds Max 2012
2 REPLIES 2
sbomhardt
231 Views, 2 Replies
I haven't the foggiest idea what I have done but all 3 symbols are replaced through two small red lines in 90°. Is there a possibility to make them appear again in their normal form. Reset doesn't help. Thank you in advance.
2 REPLIES 2
10DSpace
in reply to: sbomhardt
@sbomhardt
I think in older versions of max the shortcut key for the Transform Gizmo Toggle may have been "x".  Not sure, but you should be able to check what it is in your Customize User preferences in Max 2012.  There is no default shortcut for it Max 2022 as shown below, but you probably just accidentally hit the shortcut key for it.
sbomhardt
Great! Thank you very much.
Technology Administrators
