I haven't the foggiest idea what I have done but all 3 symbols are replaced through two small red lines in 90°. Is there a possibility to make them appear again in their normal form. Reset doesn't help. Thank you in advance.
Solved by 10DSpace. Go to Solution.
I think in older versions of max the shortcut key for the Transform Gizmo Toggle may have been "x". Not sure, but you should be able to check what it is in your Customize User preferences in Max 2012. There is no default shortcut for it Max 2022 as shown below, but you probably just accidentally hit the shortcut key for it.
