Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Reference, Editable Poly
siskinsergey623
siskinsergey623
When I make a copy ( reference ) and use an editable poly on the original object, and change it, the copied object does not change. How to fix it?
CAMedeck
It looks like you converted the original object to an Editable Poly, rather than add an Edit Poly modifier.  Once you converted the box, it lost the link to the Reference.
Chris Medeck
