Re: Redshift Problem - Red Shader after batch render
I have the same problem with 3ds max. When I render scene with single frame it appears as ok, but when I do animation one particular shader is bright red. Does anyone know anything about it?
sean.heasley
Hi @Anonymous
We don't have access to Redshift and I'm not an expert on Max so I went ahead and moved your post to the 3dsMax forum.
My co-worker @hagen.deloss  is our Max forum guru and he can take over here Smiley Happy
hagen.deloss
Hi @Anonymous
Great to hear from you on the forums! What render engine are you using when this happens?
Does this happen when you aren't using Redshift? If not, I would suggest posting your issue on the RedShift forums here.
If you are still encountering this issue, even when you aren't using RedShift, I would ask for further details regarding your materials, and scene. I have a few more questions to further understand the issue.
  • What version of 3ds Max are you using?
  • Is it possible that you have keyframed a material?
  • What material type are you using?
Looking forward to chatting further!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
hagen.deloss
@Anonymous
Any ideas or questions on my previous post? It would be helpful if you had time to give an update, that way other Community Members can benefit from your process 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Hi @hagen.deloss , I have downloaded  the new build and the problem has been fixed. Everything is working perfect now!
- 3ds Max 2018
- redshift v2.6.32 - red shader problem
- redshift v2.6.36 - fixed
I am sorry for the delay in my answer, my inbox is really crowded and I'll try to be faster in the future.
Thank you!
hagen.deloss
Hey @Anonymous
No problem, I appreciate you coming back to this thread so folks with similar issues can learn from your process 😄
Hagen Deloss
