"Edit Working Pivot" not working (Max 2018, Update 1)
Message 1 of 24
Basically when attempting to edit the working pivot via the Hierarchy tab, the gizmo will stay glued to the position of the objects pivot, no matter what I do - in transform and in rotate mode. This breaks scripts as well (which align the working pivot to sub-object selections).
Replies (23)
Message 2 of 24
I can't seem to edit my message, but the following is actually the case: The working pivot is shown to be at 0,0,0 - and stays at 0,0,0 whatever I try doing in edit mode.
Editing the regular object pivot works fine.
Message 3 of 24
RGhost77
I confirm. That terrible. 😕
Royal Ghost | veda3d.com
Message 4 of 24
I'm amazed it got through without anybody noticing. Shameful, really. Back to 2014 then, the Max2018 ride is still too bumpy.
(Thanks for confirming the bug)
Message 5 of 24
I experience the same problem editing pivot in Hierarky panel.
Have this been confirmed by Autodesk as a bug?
Any solutions in work?
Message 6 of 24
Confirming this bug happens to me as well.
Autodesk, has this been logged?
Message 7 of 24
RobH2
I can confirm that I also cannot get the 'Working Pivot' to move.
There is a simple workaround for now. Export the .max file back to version 2017, move the Working Pivot and save it. Open the 2017 .max file in Max 2018 and the Working Pivot will be where you placed it. It stuck for me anyway and worked fine back in 2018.
Rob Holmes
3ds Max (2025-2027), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Message 8 of 24
treximagery
Also confirming that "Edit Working Pivot" it is not working.
Just submitted a bug report in case no one else has (Help->Speak Back->Report a Problem).
Message 9 of 24
@Alfred.DeFlaminisIs there an ETA for a new update / hotfix / bugfixing release?
Message 10 of 24
Alfred.DeFlaminis
Hello @Anonymous,
The truth is I am not permitted to reveal release dates of updates and service packs.  What I can say is that this issue is logged (by me) as 'Critical' in the tracker.
Best Regards,
Message 11 of 24
RedTechDigit
Have anyone found solution for working pivot except rolling back version(which is quite unstable)? Two months have passed since update 1 and I can't find any way to make working pivot work(which is quite fundamental function for me).
Message 12 of 24
I don't think there is a workaround. You can use the old fashioned method of picking a custom pivot/coordinate system which uses a separate object as it's target.
Message 13 of 24
Alfred.DeFlaminis
Hello @RedTechDigit,
The next update is scheduled to come out relatively soon.  I can't say when it releases however, but it shouldn't be long now.
Best Regards,
Message 14 of 24
RobH2
@RobH2 wrote:
There is a simple workaround for now. Export the .max file back to version 2017, move the Working Pivot and save it. Open the 2017 .max file in Max 2018 and the Working Pivot will be where you placed it. It stuck for me anyway and worked fine back in 2018. .
 There is a workaround if you have Max 2017...(from my post #7 in this thread)
Rob Holmes
Message 15 of 24
This one is taking time. Hopefully we have a fix for this in a near future
bugfix/update. Autodesk have taken notice.
Message 16 of 24
Alfred.DeFlaminis
Hello @Anonymous,
Although this was logged a while back, I really appreciate when people report issues on the forums.  I will log them into the tracker if they didn't already exist and sometimes issues don't generate CER Reports so they can go unnoticed until reported.
So even though this issue was already reported and worked on internally, I thank you for reporting any issues that you find regardless.
Best Regards,
Message 17 of 24
Alfred.DeFlaminis
Hello @Anonymous, @Anonymous, @RobH2, @Anonymous, @RedTechDigit,
2018 update 2 released today which fixes this issue.  Please download and install it from the desktop app or manage.autodesk.com.  Thanks!
Best Regards,
Message 18 of 24
RobH2
 "woohoo!"
Rob Holmes
Message 19 of 24
Alfred.DeFlaminis
Message 20 of 24
RobH2
Good to hear.
I think we are all feeling a little bit raw over this being that we are only 6-months out from 2019. I'm even a little embarrassed because I was on the Beta for 2018 and caught neither "Working Pivot" nor the "RighClick Custom Buttons" issues.
At least it's behind us now.
Thanks for the update.
Rob Holmes
