Hi, I'm a student trying to learn architecture visualization.
I have an issue with trying to animate opacity, basically making and object appear or disappear.
All I Can find is related to Curve Editor or Dope Sheet but when I open the editor I can't find any objects there.
I have tried messing around with my filter options but nothing appears, also tried to change layout but that doesn't work either.
Anyone have any ideas?
Thanks in advance.
-Sam
Solved by hasa22hf. Go to Solution.
I fixed it, apparently it causes issues if you have all filters active at the same time.
Case solved basically.
Don't really know how to close the thread so I'll leave it in case it helps someone in the future.
