3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Problem with models imported from AutoCad
3 REPLIES 3
377 Views, 3 Replies
I'm using 3ds max 2017 and AutoCad 2014. When I import a model from AutoCad and select element mode in Mesh or Editable Poly it does not select the whole element but only rhe polygon i clicked on.This aloso affects edit geometry.
I will be very grateful if you can help me.
3 REPLIES 3
Diffus3d
Hello @Anonymous and welcome to the community,
Are the other elements selectable in general?  Looks like maybe the elements are not welded.  If you select all your verts and do a weld at a low tolerance, does it resolve the issue?
Best Regards,
in reply to: Diffus3d
Hi @Diffus3d  and thank you ,
I can't try welding them right now because it on my office computer,but I'm pretty shure it can not.This happen to me a while ago ,so I reinstalled all autodesk products and it desappeared.
I think its something im accidentaly doing in autocad ,because in this scene there are objects that i imported earllier and there is nothind wrong with them ...with the same settings for import.
Diffus3d
Oh ok, sounds like it's working now then?  (Good to hear.)
Best Regards,
