In the editable poly gave polygon smoothing group, upon application of the crease pg zbrush, smoothing does not work properly . It is this 3ds max error? Files of other people there is this application, not only in my 3ds max. The several types of script relating thereto , but also its application is not . The same problem occurred even install 3ds max again. In addition, another object when you apply the newly created smoothing group. I do not know how to solve . Help
Solved by Alfred.DeFlaminis. Go to Solution.
Hello @Anonymous,
I would like to try to help you with this problem. I want to apologize though because I am not totally sure what you are asking for here. I think you are asking about objects not smoothing properly after you have used GoZ to get them into Zbrush. I tried to make a video to show you ways you can control the smoothing of your model in 3ds Max. Maybe you need more polygons, or 4 sided polygons, to get what you are looking for. Please let me know if this is not what you needed, I will do my best to help you. Thank you.
Please hit the "Accept as Solution" button if my post fully solves your issue or answers your question. This lets me know that I was effective in helping you, and thank you for doing so.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
