I do not understand why all of a sudden png format does not work.
https://gyazo.com/84388e82a1c7fdd25e9968a62004ea6c
I have Alpha channel and Interlaced checked. also rgb 48 bit. Gamma is stet to Override 2.2
Here is a file that renders ok but will not produce a png when saved as.
https://gyazo.com/e82817ffc0f808c8f14b663cc8cba49b
Sorry, it's work fine in 3ds max 2016 sp1 on my PC. I can render and save as.
Could you upgrade your 3ds max?
https://knowledge.autodesk.com/support/3ds-max/downloads
I know it works fine in 2016 and 2014. Trouble is I am using 2015 with Backburner currently and would like it to work as it should. I have narrowed it down. Well it was definitely some setting in the scene somewhere. I started a new scene and merged the geometry and its fine. Strange.
