Perspective Viewport Problem
Hello I used to use 3Ds Max 2013 version and a problem popped out. When I'm using the perspective viewport the drawings get distorted. More likely when I tried to rotate the drawing image loss appears.
I started to use 2014 version and the same problem still exists. Here's screenshot of the problem. Thanks for the help in advance.
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
I am a bit late replying here and for that I apologize.  I'd like to help with this issue though.  This could be a couple things.  1) Z-fighting in 3ds max.  This can happen if faces are very close together and the camera is zoomed out a ways, or as a result of unit settings. One fix is to use viewport clipping.  2) A problem with the model.  If it doesn't render like this, then this isn't the issue.  3) problem with graphics card, which is usually unlikely.  Please let me know if one of these helps, and if not I'd like to keep trying.  I can also create a private folder for you to upload the file if you would like me to investigate it personally.  I am happy to do so.
Best Regards,
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
stevirt
Thank you!  Followed your link to Z-fighting.  Moving to the origin fixed my issue perfectly.
