Parameter window not updating in Slate Editor
nikATVHF
nikATVHF
I have started getting an issue in the Slate Material Editor where the parameter window doesn't up date properly if I select nodes of the same type ( ramp - ramp ) after each other. If I select something different between selections, it's fine ( ramp - whatever - ramp, for example ). I use ramp as an example because that's where I noticed the issue.
If you look at the attached screenshots, the ones with the purple ramps in them are actually 2 different nodes ( you can see the name is different and the highlighted nodes are different too ), the blue ramp is the one that should be displayed for 'map 7'.
This only started happening after I accidentally dragged the parameter window out of the material editor ( though that may be a coincidence )
I am using MAX2024, .1 update, and Arnold 5.6.5.0, Windows 11
Any help / solutions gratefully accepted.
RobH2
This may not help you much but there seem to be a few issues with Slate that are still unresolved in 2024.1. Keyboard shortcuts don't work properly in some situations. For instance, if you are working in Slate and hit 'Del' to delete a material or somehting, instead, Max will delete whatever is selected in the viewport. This could be one of those issues and hopefully it and others will be fixed when we get a new patch. I think we are past due for a 2024.2 patch.
Rob Holmes
3ds Max (2025-2027), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
darawork
As Rob said above, yup, this is probably just another item in a list of things that needs to be fixed with the SME.
As always, if you ever come across something like this that is obviously not user error, but appears to be a problem with 3DSMax, please report it by going to the main menu -> Help -> Feedback -> Report a problem. This will log it with the devs, and will hopefully be patched in the next update.
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
