3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
OSL Bitmap Lookup 100% CPU usage in 10 min
3 REPLIES 3
pobeda123d
256 Views, 3 Replies
Using OSL Bitmap Lookup nodes causes 100% CPU usage in 10 min when scene saved/loaded with container (saved/loaded) with materials that contain OSL Bitmap Lookup nodes.
3 REPLIES 3
RobH2
in reply to: pobeda123d
Looks like that might be a bug. I'd encourage you to report it. They'll likely get back in touch with you about it.
Bug Reports:
https://www.autodesk.com/company/contact-us/product-feedback
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
shawnolson
Thank you for reporting. We will look into this. Can you share any more details like what version of Max, what renderer you are using, etc.
If possible, can you share a sample scene?
Does the CPU go back to normal after a while, or does it keep increasing over time?
Is there a dedicated GPU, or is it integrated?
Does it happen when switching from Standard to High Quality? If so it's normal since it's forcing the shader compilation.
Giuseppe Schiralli
3ds Max - QA Analyst>
