OSL Bitmap Lookup 100% CPU usage in 10 min
pobeda123d
pobeda123d
Using OSL Bitmap Lookup nodes causes 100% CPU usage in 10 min when scene saved/loaded with container (saved/loaded) with materials that contain OSL Bitmap Lookup nodes.
RobH2
Looks like that might be a bug. I'd encourage you to report it. They'll likely get back in touch with you about it.
Bug Reports:
https://www.autodesk.com/company/contact-us/product-feedback
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
shawnolson
Thank you for reporting. We will look into this. Can you share any more details like what version of Max, what renderer you are using, etc.
giuseppe.schiralli
If possible, can you share a sample scene?
Does the CPU go back to normal after a while, or does it keep increasing over time?
Is there a dedicated GPU, or is it integrated?
Does it happen when switching from Standard to High Quality? If so it's normal since it's forcing the shader compilation.
Giuseppe Schiralli
3ds Max - QA Analyst>
