3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
No preview of map in viewport
3 REPLIES 3
colbyroper
238 Views, 3 Replies
I am working in 3ds Max 2024 and Windows 10 and Vray.  I have multiple maps on one object and using muliti-sub-object.  Everything is set up correctly as well as channel maps.  I contacted Chaos Group and they confirmed everything is set up correctly and they have seen many issues with this with Max 2021-2025.  They insured it is a Max issue because it happens to many others not using Vray.
I have never have had this issue in my many years of using the program and jumped from max 20 to max 24.  I installed all updates and I still can not get the preview to work.  In the example I attached is a tire with bumps for the sidewalls and tread.  The tread does not show up even after many attempts to show in viewport, but does show up in the render.  I feel it is an inefficient way to set up your maps by having to render to adjust and dial in your map.  Has anyone found a solution for this bug?  Thanks.
3 REPLIES 3
RobH2
in reply to: colbyroper
There have been a lot of posts stating issues with map display in the viewports in relation to Max 23, 24 and 25. I think Max 25 has possibly solved most of them. But I still think it's a little fluky and we have to endure the pain till it gets worked out. A lot of sweeping changes were made to the Material Editors in Max 24 and Max 25 and I think there are some growing pains unfortunately.
I'd encourage you to report it. The more reports they get the more likely they'll address the issues. But for now I think we just have to work around it. 😞
SUPPORT CONTACTS----
https://forums.autodesk.com/t5/3ds-max-forum/how-to-contact-autodesk-technical-support/m-p/12834730
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
colbyroper
in reply to: RobH2
Thanks for letting me know RobH2.  I guess it is what it is.  I am working on anther object, where I did have the map showing up for a short time and trying to get it to work and then the map stopped showing up entirely.  I tried contacting Autodesk, but not sure if it went through.  Received a message to change the type of account to contact them.
RobH2
You are experiencing what a lot of people are. I've used Max since before V1 and I had no issues until Max 22 or 23. Now and then the maps just don't work. The next day, they do. I think there is really some sort of bug that needs addressing. Max 2024 seems to have corrected it so far.
Rob Holmes
