I am working in 3ds Max 2024 and Windows 10 and Vray. I have multiple maps on one object and using muliti-sub-object. Everything is set up correctly as well as channel maps. I contacted Chaos Group and they confirmed everything is set up correctly and they have seen many issues with this with Max 2021-2025. They insured it is a Max issue because it happens to many others not using Vray.
I have never have had this issue in my many years of using the program and jumped from max 20 to max 24. I installed all updates and I still can not get the preview to work. In the example I attached is a tire with bumps for the sidewalls and tread. The tread does not show up even after many attempts to show in viewport, but does show up in the render. I feel it is an inefficient way to set up your maps by having to render to adjust and dial in your map. Has anyone found a solution for this bug? Thanks.
There have been a lot of posts stating issues with map display in the viewports in relation to Max 23, 24 and 25. I think Max 25 has possibly solved most of them. But I still think it's a little fluky and we have to endure the pain till it gets worked out. A lot of sweeping changes were made to the Material Editors in Max 24 and Max 25 and I think there are some growing pains unfortunately.
I'd encourage you to report it. The more reports they get the more likely they'll address the issues. But for now I think we just have to work around it. 😞
SUPPORT CONTACTS----
https://forums.autodesk.com/t5/3ds-max-forum/how-to-contact-autodesk-technical-support/m-p/12834730
Rob Holmes
Thanks for letting me know RobH2. I guess it is what it is. I am working on anther object, where I did have the map showing up for a short time and trying to get it to work and then the map stopped showing up entirely. I tried contacting Autodesk, but not sure if it went through. Received a message to change the type of account to contact them.
You are experiencing what a lot of people are. I've used Max since before V1 and I had no issues until Max 22 or 23. Now and then the maps just don't work. The next day, they do. I think there is really some sort of bug that needs addressing. Max 2024 seems to have corrected it so far.
Rob Holmes
