3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
New unwrapping / texel density problem
2 REPLIES 2
raymondwganderson
1150 Views, 2 Replies
raymondwganderson
  • Hi folks,  Just when I thought I had my unwrapping / texel density sorted.  I created a new model and followed the same procedures that worked perfectly on the previous model but when I bake the maps in Substance painter there is a weird stripe showing.  I have attached a few pics. of my unwrapping ect. Also noticed that when I opened the UV editor it took quite a while for the "flatten" dialogue  to become active.  Just when I thought all was good !
2 REPLIES 2
raymondwganderson
Just think I have solved the problem.  In the model I created a boolean [ as all the parts will be welded together but... I clicked the  Adjust non manifold positions and merge [ Solid Edge Mcad ]  that threw my unwrapping in Max haywire. So now  seems to be good again. Everyday is a learning day.
lynn_zhang
Hi @raymondwganderson
Glad to hear you fixed the problem, another learning experience, isn't it?
Thanks so much for sharing the solution! This will benefit other users in the community with the same issue.
Lynn Zhang
Lynn Zhang
