I'm creating demo for game engine test.
I don't know it's done by Game Engine(Unity3d or Unreal engine) or 3Ds max (or any other 3d software).
i want to do like this like in Real Racing 3 >
here is link : https://www.youtube.com/watch?v=UT_snPGnBJU
Please guide me, how can i do this.
i tried UV unwrapping but didn't get continues mapping as my mesh model have separate mesh elements.
I tried UVW map and applied box to make continues but in final i got uv overlapping.
i have a bus model and i want to project decals on it in unity3d engine.
Even small help will be appreciated.
Thank you 🙂
Solved by 10DSpace. Go to Solution.
@Anonymous
You are thinking along the right track with Unwrap UVW. You just need to understand the basic principles so you can apply them to your Bus model and any other texturing work you want to do. Here is a link to several basic introductory video tutotrials to the Unwrap UVW modifier in max that will ground you in the basic principles.
This tool does take some time to completely master because there are multiple ways to Unwrap and it really helps to know the easiest approach for a given mesh, because they can vary a lot in terms of shape, detail, etc. So my recommendation to you is to take the time to gain a solid understanding of the Unwrap UVW modifier by listening to the 3 intro videos in the above link and read the Autodesk Help documentation on the subject as well. The time will be well spent, because Unwrap UVW is at the heart of a good texturing workflow. There are many questions on this forum that are simply the result of a user not understanding the basics of UV unwrapping.
I hope this helps you on your way.
