mrMaterialAttribs.gup terrorizing my workflow on every step
alex.motion
Message 1 of 58
alex.motion
Hi !
using max 2019 , that issue appears every time I'm importing xref or adding custom path for textures
any workaround to get rid of that plugin window appear every time ?
Replies (57)
Message 2 of 58
irishman_team_kilber
what plugin are you using?
How to disable 3rd-party plugins
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/3ds-Ma...
remove missing plugins
if this does not work then try this script http://www.scriptspot.com/3ds-max/scripts/removemissingplugins
Message 3 of 58
scionik_andy
Fresh installed 3ds Max 2020 occurs the same. mrMaterialAttribs.gup is missing on startup. Created the new path to maxstart.max (cleaned by script) doesn't help.
Andrey Plaksin CG Artist
portfolio
Facebook |Personal project
Находите сообщения полезными? Поставьте Нравится (Like) этим сообщениям!
На ваш вопрос успешно ответили? Нажмите кнопку 'Утвердить решение'
Expert Elite Member
Message 4 of 58
alex.motion
neither of those methods work , still appearing that message
any workaround ??
"FileName: mrMaterialAttribs.gup     Class: mental ray.....etc etc"
"FileName: mrmaterialAttribs.gup     Class: displacement mental ray.....etc etc"
dll decription Material Custom Attributes (Autodesk)
I'm pressing open and then after 2 3 seconds again
that time only one line and then I'm pressing open again and only then it continues to open scene
where to take those 2 gups and where to paste them ?
Message 5 of 58
Message 6 of 58
alex.motion
He solved that problem coz he was able to install mental ray for max
but there in no mental ray for max 19 and 20 so I'm still in trouble
thank you for you help and waiting for AD advice
maybe someone from devs can share that 2 3 4 files and tell us where to put those to get rid of that annoying issue
Message 7 of 58
@alex.motion MR has been discontined unless you downloaded it in 2017 autodesk stop using it and change to the art renderer
http://www.cgchannel.com/2017/11/nvidia-discontinues-mental-ray/
how to download MR https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Message 8 of 58
alex.motion
I did that days ago but mental ray wont start installing
screen appears and then disappears again
I tried to unzip installer and even found that **** file inside but I don't know where to put it ...
when I put that file into plugin folder max says it's not for that version ...
underwater stones ...
Message 9 of 58
final message i am not sure if the MR is a plugin or what.
Plug-In Manager
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/3DSMa...
3rd Party Plug-Ins Path Configuration
maybe @dgorsman can help when he/she is online or @raiden_xavier maybe start a new thread. on mr
best of luck to you
Message 10 of 58
alex.motion
I think scene converter should do the job
I'm not asking you to respond )) relax .
if I will manage to get rid of it with help of SC I will post here
Message 11 of 58
alex.motion
open scene then go to render scene converter when it opens
delete missing mrattribute listed in yellow color and that's all
it solved my issue
Message 12 of 58
marc.pat
Mental ray for 3ds max 2018 run weel in win 7, if you try to install on win 10 in many case the installer dont' start.
Message 13 of 58
jacob
This was killing me, its so frustrating.
Anywho.
Im pretty sure its trying to call an MR Parameter in the render defaults (like light MR shadows)
which doesn't exist anymore
change the default renderer to scanline (no mr) and it seems to go away.
do this go custom defaults switcher - i picked max Default UI.
Had to redo my custom UI buttons, but far out, that pop up was a killer
Message 14 of 58
So I have not been using mental ray since 2007, and I installed a clean 3ds Max 2019 now and I am getting this error with literally every file in the studio. And we are using Corona.
I understand scene converter can be set to remove missing legacy plugins, but it doesnt get rid of the missing dlls error on every other old file that I havent removed legacy plugins. It is 2 popups, one is for missing dlls and the other one is scene converter trying to confirm conversion.
This is very , very annoying to do for every asset file , because of a plugin that I didnt use in the first place .
Will I have to lose 2-3 minutes every time I open a file for the rest of my work days ?
Isnt there a way around it ? Cant 3dsmax deal with this internally by not giving me an error window ?
Message 15 of 58
RobH2
I just wanted to weigh in also. I'm still chronically terrorized by this error. The 'Solution' here may work for some but now for me. I think this bug goes beyond having the Render Converter try to manage it.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Message 16 of 58
josephriehl
Just wanted to bump this so i may get a response as well
I'm also using corona and get this error in max 2018.
I had previously gone through the steps of installing mental ray but have since done a fresh install of max 2018 because when i DID have mental ray installed (which of course i never use anyway), There was some third party application that would start, asking me to update each and every time i opened a scene (so actually more annoying than the error message itself). updating the settings to 'dont check for updates' did not work, so it started each time regardless. So that is what led me to the fresh install.
Message 17 of 58
nate
Fresh install of 2021. Start Max, go to physical material change Preset. Immediately get this error. Any ideas? Is this a corona specific issue?
Message 18 of 58
MBetke
I also got this error from multiple files.  Its just from a fresh 3ds max 2021 installation.
After using Scene Converter I still get the "mrMaterialAttribs.gup" prompt during loading.
I also tried to clean it with the "removeMissingPlugins" script.
Can't get rid of this message. back in 3dsmax 2019 I just was able to copy over the old MR plugins but it doesn't work anymore.
Message 19 of 58
nate
I don't even have to open a scene. Just change preset in Physical material after just opening MAX. I can't recall if this issue was there before installing Corona. I may uninstall and check. I had just installed hotfix 2.
Message 20 of 58
josephriehl
Just want to mention i've got the same issue on a fresh install of max 2021 (using Corona to render). every Xref file i own, this message pops up when merging/copy pasting into a scene. the Silentium script at least suppresses it repeatedly, but still i feel it could be faster if it didn't appear at all. Would like to know how to fix it if possible. Thanks.
