3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Modifier list doesnt appear
7 REPLIES 7
Message 1 of 8
2929 Views, 7 Replies
Hi people, well first of all: Im new here so "hi" to you all 🙂
My first question here is going to be a troubleshoot about the Modifier list.
When i have an object selected (doesnt matter what kind of object) and i hit the modifier list -combo box, it appears to 'notice' that i click on it, but nothing happens.
The list does not appear at all.
I already re-installed Max 2009 and still no wanted result.
Does anybody got an idea?
Thanks 🙂
7 REPLIES 7
Message 2 of 8
Steve_Curley
A guess? An Intellimouse - remove the drivers (ditto for the Logitech Setpoint drivers). May not help, if not just reinstall them.
Oh, and search these forums - this issue has cropped up before.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 3 of 8
Hi Gunblade! Currently I'm having a similar problem. Whenever i click on the modifier dropdown with a object Max crashes. The same thing happens when i make a NURBS surface (UV loft, for example). I wanted to ask - can you make NURBS just fine?
Message 4 of 8
@ Steve Curley: I have been fiddling around with my mouse-settings + drivers etc.
And i have noticed that it wasn`t that at all, instead it only happened while being maximized in the 2th monitor (dual view on a Wacom-tablet, im sorry i should have said so).
When i made the 3DsMax-window smaller, it was active again.
.... in other words, it is just a screensize-bug, since the list doesn`t appear when on fullscreen on a monitor on who doesnt fit a full list of the modifier-stack.
@ Sentinel12: No, i can make NURBS without any trouble, but if you read the conclusion above you`ll know why 🙂
Message 5 of 8
Does your list go upwards instead of dropping downwards? I had an issue where I had the command panel on a second monitor and the first time I would click on the modifier list, the list would extend upwards only showing a little bit of the list. I would click it once more to close it and another to open it back up and it would extend downwards. I never really investigated it and now I have a larger monitor with the command panel on the first monitor, but if I put it back to the other position on the second monitor, it does the same thing again.
Message 6 of 8
ekahennequet
This is an old thread, but it discusses the very issue you're referring to.
area.autodesk.com/forum/Autodesk-3ds-Max/3ds-max-through-2008/modifier-list-bug--drop-down-box-only-...
Message 7 of 8
My modifier list keeps crashing max when i click on it. Does anyone have a solution to this problem? Thanks in advance.
Message 8 of 8
hafza2163
hi I'm a beginner
my modifier list is not showing up in 3ds Max windows 10 kindly help ....
Technology Administrators
