I just noticed that some command panel items are missing. For instance, when I go to create Geometry Particle Systems, only 6 object types are listed with PArray missing. What am i missing other than that command?
Solved by terry. Go to Solution.
What screen resolution / windows scaling are you using?
Did you try resetting your user settings? (WARNING: All your customizations will be lost)
This is how it looks like in 2020.2 here:
I've looked at my 3ds Max 2020, and am showing 7 items in that set. So you're only missing PArray.
As to why that happened, I'm not sure. You could attempt a reinstall, or repair, to see if that fixes it. It seems like maybe the file for PArray is missing. Are you getting any errors when you start the software?
Chris Medeck
Thank you. I saw that I missed the last update. I installed that and now the panel is correct. Thanks again for your help.
