3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Missing Items in Command Panel v2020
3 REPLIES 3
terry
490 Views, 3 Replies
terry
I just noticed that some command panel items are missing.  For instance, when I go to create  Geometry Particle Systems, only 6 object types are listed with PArray missing.  What am i missing other than that command?
3 REPLIES 3
in reply to: terry
What screen resolution / windows scaling are you using?
Did you try resetting your user settings? (WARNING: All your customizations will be lost)
This is how it looks like in 2020.2 here:
CAMedeck
in reply to: terry
CAMedeck
I've looked at my 3ds Max 2020, and am showing 7 items in that set.  So you're only missing PArray.
As to why that happened, I'm not sure.  You could attempt a reinstall, or repair, to see if that fixes it.  It seems like maybe the file for PArray is missing.  Are you getting any errors when you start the software?
Chris Medeck
Chris Medeck
terry
in reply to: CAMedeck
terry
Thank you.  I saw that I missed the last update.  I installed that and now the panel is correct.  Thanks again for your help.
