Mirroring animations
aftonmason84
aftonmason84
Community Visitor
Community Visitor
Hi all, I'm asking to see if there is any easy way to mirror animations of an object (i.e., object A moves to the left 20m, but when mirrored it moves to the right by 20m instead) easily without making the scale negative. The reason the scale must remain positive is that the game engine I am exporting this to does not support negative scale and will invert the scale back to positive upon export, completely messing up the position of the object in game. It also means I can't use any special modifiers that are not exportable. I have a lot of objects with complex animations that I would essentially have to redo if there is no way to copy them and mirror them without using the mirror tool. https://omegle.onl/
A娘
you can set by flip animate curve , if there are lots nodes , you may need set by script
as your example , your A at [100,100,100] at time 0f , and next key at 100f move to [80,100,100] , then you set 100f to [120,100,100] , your animation changed to move right 20 from move left 20
MartinBeh
Maybe you could first use a negative scale on a parent helper, and then later bake the animation of the children?
Here is a little utility for that in case you want to try.
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
joaquim.moral
Hi @aftonmason84
Did the information provided by @A娘 and @MartinBeh answer your question?
If so, please use Accept Solution so that others may find this in the future.
If not, let us know so we can keep helping you.
Thank you very much!
Your question got successfully answered? Then just click on the 'Mark as solution'
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Joaquim Moral
Senior Community Manager
